It is currently Tue Jun 24, 2025 11:48 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Sun May 07, 2006 11:03 pm
Al, thanks for sharing the plans. One question; what did you mean by "nut end of board should be as close to small radius as possible" when talking about using it for a compound radius?
             Thanks, Paul Harrell
PostPosted: Sun May 07, 2006 11:42 pm
Yes. When making a compound radius, the actual starting radius will be a function of where the fretboard is located on the table. The minimum radius will be right over the short arm, and the max will be over the long arm. If one wanted to an extra set of pivot holes could be drilled to allow greater taper, or a more precise taper.
PostPosted: Mon May 08, 2006 12:50 am
Thanks for the answer and thanks for taking the time to post the plans for everyone.
                Paul
PostPosted: Mon May 08, 2006 1:28 am
Here is my version of a similar radiusing fixture. I think it is about a 14" radius on the nut end and about a 20" radius on the saddle end.
PostPosted: Mon May 08, 2006 2:01 am
Looks real good John....I assume that it's the male of the species right?
Cheers Kim larkim38845.4600694444
PostPosted: Mon May 08, 2006 2:27 am
Thanks a lot Al! This will be in my future plans. Nice drawings too
PostPosted: Mon May 08, 2006 3:52 am
Thanks for the plans Al! I'm gonna have to build one of those. Radiusing is pretty slow just using the blocks from Stew Mac.
PostPosted: Mon May 08, 2006 3:54 am
John I like your jig. Just goes to show that it's rare to come up with something totally origional.
PostPosted: Mon May 08, 2006 4:27 am
I didn't come up with it either, I found it on Bo Walker's site. So there ya go. Don't know if it was his original idea or maybe he saw it somewhere else as well.
PostPosted: Mon May 08, 2006 5:12 am
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
       Hi. I am still learning and would like to know why and when to use a compound instead of a straight radius. On my first fretboard I just cut a scraper matching the radius on a guitar I have and it worked fine. Of course it wouldn't work for a compound though.
I notice some of the jigs seem to be more complicated than necessary but must somehow make production work faster and more accurate. I like to avoid using a router whenever possible in favor of simpicity and noise avoidance.
PostPosted: Mon May 08, 2006 5:21 am
Early Fender guitars had a very tight radius to the fretboard, and followed the natural curve of the fingers. The problem came up when players would bend the strings especially higher up the neck. As the string is bent sideways the arch of the fretboard would cause the string to fret out on the next fret. Gibson guitars with their flatter fretboard were not as prone to this problem. Thus the compound radius was born to provide the best of both.
PostPosted: Mon May 08, 2006 1:53 pm
Somebody build me one, let me know what it will cost and send it to me. I feel like Fred Flinstone sometimes living in the prehistoric times when I look at some of these jigs and tools you guys make.
PostPosted: Mon May 08, 2006 3:29 pm
Mike, you got a PM!
